Bisection method - Change a Mathcad logical scheme to another
  • May 25, 2020
  • 2 replies
  • 4068 views
Hello, I want to change an existing Mathcad scheme of solving to another described in a flowchart.    I cannot.   I attached the Mathcad file where I try, and also the Flowchart that I want to implement.
Enclosed does the trick.
Cheers
Terry
tubar1-VisitorAuthor
Thank you very much. We are very closed on what I want to obtain.  And BREAK command how I implement ?:
Break, if f(x_i)=0
Also, in the new obtained form (attached) I cannot obtain the table of iterations i  vs  x_i.
Hi
Break, if f(x_i)=0
Go to View | Toolbars | Programming.  This will bring up a toolbar with "break" and "continue".  You must use the toolbars not type the words.
Looking at the code provided.
Cheers
Terry
The strategic direction of solution of various scientific problems, including the problem of creation of artificial intelligence (AI) systems, human brain simulators, robotics systems, monitoring and control systems.
