Calculating the speed of sound in wet steam
Does anyone have a method for calculating the speed of sound in wet steam?
The standard method works for dry or superheated steam, but breaks down rapidly at and below saturation temperature.
The 2015 paper by Šafařík, November, Jícha and Hackman "On the speed of sound in steam" shows a discontinuity in the speed vs dryness curves at about 0.98 dryness, but I do not know if that is supported by measurement.
Sorry, spelling checker has mangled the names mentioned above. They should be Šafařík, Nový, Jícha, and Hajšman.
18-Opal
THE SPEED OF SOUND IN STEAM (asee.org)  - dont know wet or dry
Sound Speed in Liquid‐Gas Mixtures: Water‐Air and Water‐Steam (illinois.edu)
But I guess you can search just like I did and this is not it!
and Chat GPT says
 And  Gemini AI says:
If you need a rough estimate, you might find references to the speed of sound in wet steam being around 10% lower than dry steam at similar conditions. However, this is a simplification and won't be accurate for all cases.
terryhendicott
Your reference says no measured data is available?:  But there is one that has measurements of wet steam.
ON THE SPEED OF SOUND IN STEAM
Pavel Šafa?íka,?, Adam Novýb, David Jíchaa,b, Miroslav Hajšmanb
Papers [5, 6] provide much stimulation for further studies of the speed of sound in wet steam, because they deal with the propagation of waves in wet steam. However, no measured data have in fact been published.
[5, 6] are not this article:
Velocity of Sound Measurements in Wet Steam
R. E. Collingham and J. C. Firey
TY - JOUR
T1 - Velocity of Sound Measurements in Wet Steam
AU - Collingham, R. E.
AU - Firey, J. C.
Y1 - 1963/07/01
PY - 1963
DA - 1963/07/01
N1 - doi: 10.1021/i260007a005
DO - 10.1021/i260007a005
T2 - Industrial & Engineering Chemistry Process Design and Development
JF - Industrial & Engineering Chemistry Process Design and Development
JO - Ind. Eng. Chem. Proc. Des. Dev.
SP - 197
EP - 202
VL - 2
IS - 3
PB - American Chemical Society
SN - 0196-4305
M3 - doi: 10.1021/i260007a005
UR - https://doi.org/10.1021/i260007a005
ER -
Emeritus
Hello @GerardLardner
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
