Complex Numbers in Polar format
  • January 21, 2016
  • 2163 views
I just installed MathCad and I’m wondering if there is an easy way to display complex numbers in polar format, or even preferable display it in degrees.
For example, say I have a resistor and inductor. R1= 10 and L1 = 10j. I would like to display it as:
R1 + L1 = 14.14 with a 45-degree phase angle.
I see some stuff that might be help from about eight to ten years ago, but I was hoping there is much more simple way with Mathcad 3.1
Best answer by RichardJ
Put the cursor in the units placeholder in the result, select the format you want from the menu:
RichardJ19-TanzaniteAnswer
bhoffman1-VisitorAuthor
Thank you, it works great.
In old Mathcad
