qc is determined in each z point . I need to find the average of qc in each layer . the layer thickness is dz
I need mathcad to find the average values of qc that correspond to dz values
I am limited to Expresss so can only solve using subscripted vectors and matrices.
Enclosed is worksheet that gets the averages.
Cheers
Terry
Cheers
Terry
thank you for your help
Why do you think I'm having this error although I just followed your sheet ?
Can you upload your worksheet.
Cheers
Terry
If you have a full license for Prime the watermark will vanish.
Cheers
Terry
sure here you are you will find the calculation on page 9
See enclosed it is now calculating averages.
Problem was z is previously designated as a nested matrix. Need to define z as a single vector.
Cheers
Terry
