HYPERGEOMETRIC FUNCTION
  • January 27, 2013
  • 2 replies
  • 3028 views
Can MathCad calculate and plot a hypergeometrical function
capGAMMA of three variables, say u,v,w ???
Thanks for the help.
Anousheh
23-Emerald V
January 27, 2013
Which hypergeometric function did you have in mind? Have you looked at the built-in function fhyper (the Gauss hypergeometric function 2F1(a, b, c, x))?
Stuart
Anousheh1-VisitorAuthor
Please see the attached MathCad file. It explains what I need to do.
Please see if you can help.
Thank you so much.
Anousheh
Which Gamma function are you referring to?
How ist that Gamma defined?
Mathcad knows about Euler's Gamma and the incomplete Gamma (with two arguments)
See the definition out of Mathcad's help
Also Wolfram Research does't know about a gamma function with three argument.
BTW, I'm confused about your derivations. You write Gamma(a,x,1) and so you define Gamma being dependent from x, but your derivation behaves as if Gamma is a constant in respect to x???
Anousheh
Apart from Gauss and confluent I'd guess not out of the box.
What hypergeometric function you are interested in?
http://mathworld.wolfram.com/topics/HypergeometricFunctions.html
More information soon.
