Identify starting points
  • January 27, 2025
  • 2 replies
  • 3373 views
Hi there
I have some data of depth of 10 inputs  but I need the calculation to start from single point in each input and ignore the one above : for example the starting point of first input is 1.31 but its depth starts from (0) ...so I need the program to ignore all the data from 0 to 1.31 and starts at 1.31.
the second input d2 has values from 0.5  I need the program to ignore this values and starts from 1.26
so basically it eliminates all the points before the starting points I decided
Prime 10 is attached
also the excel sheet
Best answer by terryhendicott
Can you answer one question:
In screen grab in post all values of starting point are positive
In your file there are some negative values
Which do we follow?
match as a function by default looks for equal values {you can change this}.  This means the depth must be in the CPT to get a match.
I have changed some of your start values to match values in the CPT's.  4.27 for 4.26, 4.15 for 4.14, 4.13 for 4.12.
If you wish to keep starting;z subscript cpt.pos as the values you have that do not appear in CPT's you can add the "geq" greater than or equal in the match function.
Not sure but are you looking for something like shown in the attached file?
I prefer programmed for loops over worksheet range variables...
Thank you Terry.
