Dear mathcad fans,
I would like to know how to solve an equation for a variable?
I have an equation with two unknowns L1 and C1 (see attached), and I want to solve it for L1, ie in the form L1=f(C1).
Any idea how to get that?
Thank you in advance.
Thanks Alan. Brilliant as usual.
Now I want to plot both solutions in an XY-Plot for C1 ranging from 10^-12 to 50*10^-12 in steps of 0.1*10^-12 (unit for C1 is farad).
The problem is that i get an error message "plotting failed. Replace complex values and NaN by real numbers".
What is wrong?
What is wrong?
What are the values (and units) of w700, w960 and Lp700?
I've shown a plot in the attached, but of course the values of the above are quite arbitrary - you will need to replace them with the correct ones.
Alan
I am still struggling with plotting under Mathcad Prime.
Can anyone please have a look at the attached file? Always I think I have finally understood how to plot under mathcad but this is unfortunately not the case.
P.S: Is it possible the change the value for C1 only one time and get simultaneously the results for L1 and L2?
