Simple? numeric + symbolic calculations
  • February 12, 2019
  • 4058 views
Hi! I'm new to mathcad and trying to calculate some very simple equations containing symbolics and numerical elements. I know which answer to get, but simply can't make mathcad return the wanted result.
1/2 * cos(v) * p * L + 1/2 * sin(v) * p* L
I look for the result looking like: 0.67 * p * L
I tried searching for solutions for this but can't really find an answer, but it seems so simple that I can't possibly think that what I look for isn't possible?
Any chance there's an easy workaround?
Best answer by LucMeekes
Mathcad has a numeric and a symbolic processor that work sort of independently from each other. The numeric processor is involved when you type = after an expression. It requires all variables to be numerically defined. It knows about units and conversion between them.
The symbolic processor is called with the right-arrow operator. It accepts undefined variables and always tries to produce an exact answer. Note that 1/2 is an exact ratio. In contrast 0.5 is a number with finite precision. The symbolic processor does not know units. It treats them as undefined variables.
ttokoro
Solved.
t.t.
MC_BT_181-VisitorAuthor
Thanks, although it's not quite there yet. I know this is a more exact solution, but was hoping for a numerical value before p * L. I guess this is as close as I can get?
See what happens if you change at least one of the 1/2 to 0.5...
