Hello.
Where can i see when my mathcad student license expires? Because i have installed the program on 2 different computers, with the same key. But they dont have the same expiration date??
Hope you can help....
Andreas
license file could be located in C:\ProgramData\PTC\Licensing directory or in its sub-directories. if you open license file in Notepad and look into INCREMENT line, you will find expiration date.
MH
Hi Andreas,
If you are using a Mathcad Prime version then go to "File" (the button with "M" letter) -> "Options" -> tab "License" -> "Expiration date".
