frequency response
  • April 26, 2012
  • 4664 views
I want the frequency response of F(s,Iabc).
I don't see why that don't to display.
Do you can to help me.
Thank you very much
Best answer by Fred_Kohlhepp
There are two ways to get a subscript:
If you want a subscript in a variable name, type "I.abc"
If you want to address an element of a vector, type "I[abc"
In your sheet you define i from 0 to 100 (an index variable) so don't type sx(i) {this defines a function}, type "sx[i", and sx becomes a vector of frequencies.
You need to read the help files about units--you're putting thrm in in some places and not others.
Hello Julia,
I see several culprits in your worksheet:
#1 you haven't defined the variable Iabc. And you're using it on both sides of your equation.
#2 you're using min and max as avariable. These are however, MathCad functions and shouldn't be overwritten.
#3 the same applies to your function s(i). s is a unit in MathCad.
Hope this helps
Raiko
I have corriged the errors that you say to me but that don"t work.
Why ? Please
I try to reproduce the example on page 3-4 of this extract : ssm2040 filter analysis part 1 'write that in google and the first site internet.
Can you help me, please.
Thank you very much
