Nov 5, 2025 1:36 PM UTC
Warning popup when editing text
Using Creo Elements Direct Modeling Express 9.0
New to Creo Direct Express and creating first drawings of parts and assemblies. Each time I edit the text on a drawing (title blocks, BOM's etc) a msg is displayed similar to the the one attached.
What does this mean? Is there another way I should be editing these items?
A second question is when creating the BOM's using the scan, table, draw method, why doesn't the part number populate?
der_Wolfgang
Nov 8, 2025 10:19 AM UTC
In general:  you see those warnings when editing texts in Annotation when then text's content is calculated automatically.
In this case the Part Name of one item which is part of the BOM. The Name is inquired from the 3D Object which is part of you assembly.. If you think about the column 'Quantity' it s more obvious that this value is calculated.
You can customize your BOM e.g. by adding a new columns / write your own functions to get information of the item listed in your BOM (e.g. an order Number). But that's not for beginner.
You see the same/similar message when you edit some texts of the title block.  example : the sheet number . This is filled in automatically.
All those texts are handled as 'text references' in Annotation.  Those are texts getting their contents automatically by calling some functions.
you should not edit those texts manually.
More information can be found in the Modeling help:
● cad.de + osd.cad.de ● java-forum-stuttgart.de + jugs.de ● notepad-plus-plus.org ●
Nov 6, 2025 2:44 PM UTC
I'm not sure but if this can help.
The BOM has been filled automatically by Modeling Express. If you want to change the part name, then rename the part and update the BOM.
The part number comes from Model Manager or Windchill. Modeling Express cannot work with these two systems.
der_Wolfgang
Emeritus
Nov 12, 2025 11:06 AM UTC
Hello @BM_14348853,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
