9-Granite
March 19, 2022
Kepserver User Manager credentials
  • March 19, 2022
  • 2 replies
  • 13265 views
All,
>I'm trying to connect Microsoft Excel with Kepware through DDE. for the same i need to do some changes in settings configuration.
>But settings field asking for User Manager Credentials which im unable to enter.
>Can Anyone suggest which one will be the credentials or where can i find these details !!!
Awaiting response !
Best answer by KCorrigan
The credentials that you are being prompted for are the KEPServerEX server Admin username and password.
These were setup at the time of install.
If you do not know these credentials you will need to follow the instructions in the following article:
https://www.ptc.com/en/support/article/CS294705
Best Regards,
KC
Sathya9-GraniteAuthor
9-Granite
March 20, 2022
Hey,
This solution is great.
but my hurdle is, im unable to complete first step itself. i.e setting up of server for Interactive mode.(please see the attached image)
when i try to open the "settings" command it is asking for "User management credentials".
Please suggest a way to reset the credentials or to find the current credentials.
waiting for a solution.
thanks.
KCorrigan14-AlexandriteAnswer
Best Regards,
KC
9-Granite
March 22, 2022
Thank you very much.
Solution worked for Kepware 6.9 version...
SB
