Conch shell in Creo Parametric
- November 27, 2011
- 28 replies
- 9264 views
Hi all
how about this one for a problem to solve. I am trying to create a conch shell using the helical sweep tool, I can do it so far and then I hit a brick wall namely my mathematical ability, or should I say lack of mathematical ability. The conch shell is creted in nature obeying rules that can best be described by the using Fibonacci principles. That is the bit that beats me. Using the Vary Section option I can create a pseudo conch shell. See below
What I would like to do is now vary the pitch so that it changes related to the fibonacci series. Has anyone any clues to how I might do this. The Hel;ical sweep has a variable pitch function in Creo Parametric by setting a series of points along the profile curve axis. If I can set the points in the ratio of 1.618 , the golden section I think I can do it. Am I on the right track? I attach my Schools Edition file just in case anyone else would like to play.
