11-Garnet
May 27, 2024 5:14 AM UTC
How we can sort X-Axis and Y-Axis in scatter plot chart
Hello ,
How we can sort X-Axis and Y-Axis in scatter plot chart , as in service we can either sort data based on x-axis or y-axis, but can we have any option in chart so that both axis can be sorted.
Here is the screen shot of scatter plot and i want to x-axis and y-axis both should be sorted ascending.
Emeritus
May 30, 2024 10:04 AM UTC
Hi @PP_10477715
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team.
11-Garnet
May 30, 2024 10:10 AM UTC
Hello ,
I have already attached the screenshot where Y-axis data is not sorted, i have used line chart (ChartType="ScatterPlot")
i have two property Test1 and Test2 and i am creating Scatter plot for these two props , in Service data is sorted based upon Test2.
I want to be data sorted on Y-axis as well.
The issue here you can see data for Test1 (Y-axis) is not sorted,
