3-Newcomer
April 2, 2025
Measuring the entire surface of body [creo 11 student]
  • April 2, 2025
  • 372 views
I tried to measure the entire surface area of the body. How do I handle the error message “This measurement cannot be performed on that reference set.”?
Could you share some of your wisdom with me?
Community Moderator
April 10, 2025
Hi @TL_10695623,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
  1. Could you describe the steps you've taken so far to measure the surface area?
  2. Are you working with a specific type of model or geometry that might be causing this issue?
Adding such information could help you to receive more meaningful response from the peers.
Thanks & Regards
Vivek N
Community Moderation Team.
