PLS HELP! After Installation creo shutting down
  • September 14, 2017
  • 9 replies
  • 15746 views
Hi ptc community,
I installed creo 2.0 for students with the installation guide, but if I open it i got a Message :
' Creo Parametric is shutting down.
Cannot register Quality Agent insufficient User Acces.
Under administrator priviliges, *either customize the Creo Parametric installation to enable the Quality Agent,
                                                 * or run Cre Parametric once to allow proper registration. '
I hope someone can help me, it would be really nice! Thanks in advance!
Jeff 😞
try following:
  • uninstall PTC Quality Agent item
  • install PTC Quality Agent item using qualityagent_32.msi
  • qualityagent_32.msi is located in install\addon sub-directory of Creo installation media (~4GB zip file)
Jeffnick1-VisitorAuthor
Hi Martin,
thank you for trying!
But it still doesnt work...
It still shuts down :(((
Any other solutions or ideas?
Best regards,
Jeff
after trying a few things, what worked for me was going to the download folder Downloads\MED-100WIN-CD-470_10-0-0-0_Win64\install\addon, and clicking on the qualityagent_64, and uninstalling through here, then reinstalling by clicking the same qualityagent_64 install file, then run the creo app as admin.
Thank you, that worked for me.
