Jan 17, 2026 4:44 AM UTC
ProXsecCompXhatchStyleSet&Hatch
I'm a student and I have a question. Could you please explain how to use the method "ProXsecCompXhatchStyleSet"? I want to change the pattern of the section lines in the perspective view, but I'm not sure how to use this API or how to use other related APIs. Can someone help me?
Jan 17, 2026 4:15 PM UTC
Emeritus
Jan 23, 2026 5:36 AM UTC
Hello @ML_14468763,
It looks like you have a response from a community expert. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
Feb 26, 2026 3:37 AM UTC
ProXsec p_xsec;
ProError status;
ProColor warning_color;
ProXsecNewXhatchStyle p_xhatch_style{};
warning_color.method = PRO_COLOR_METHOD_TYPE;
warning_color.value.type = PRO_COLOR_WARNING;
status = ProXsecNewXhatchStyleCreateFromName(L"Wood", warning_color, PRO_XHATCH, &p_xhatch_style);
if (status != PRO_TK_NO_ERROR)
return;
ProXSectionItem* xsec_item_arr;
ProXsecMdlname p_xsecmdlname;
status = ProXsecMdlnameAlloc(xsecMdl, p_xsec.xsec_name, &p_xsecmdlname);
return;
status = ProXSectionItemsCollect(p_xsecmdlname, NULL, &xsec_item_arr);
return;
int n_xsec_items = 0;
status = ProArraySizeGet((ProArray)xsec_item_arr, &n_xsec_items);
for (int ii = 0; ii < n_xsec_items; ii++)
status = ProXSectionItemXhatchStyleSet(xsec_item_arr[ii], item.view, L"Wood", &p_xhatch_style);
status = ProXSectionItemsArrFree((ProXSectionItem**)&xsec_item_arr);
ProXsecRegenerate(&p_xsec);
11-Garnet
Mar 3, 2026 4:52 AM UTC
@XC_14458268  Thank you so much, I was stuck into this finally got it right.
Mar 5, 2026 7:52 AM UTC
You're welcome! I happened to be looking into this as well. Glad you got it sorted!
