Jul 11, 2017 2:02 PM UTC
Survey - direct Mathcad files attachments
While this topic may belong to "Community Help" I post it here on purpose to reach the right people.
Some of us already made the experience that Mathcad files can't be attached directly but must be zipped before we are allowed to attach them. Thats cumbersome - especially compared to the way we could make attachments in the previous forum.
I already posted a thread here
https://community.ptc.com/t5/Welcome-How-To-s/Attachment-of-files-from-PTC-products-not-accepted/m-p/476440#M156
and @Tmetcalf is already aware of the problem but has no solution so far.
Now I noticed that at least two times in this forum users were able to attach a Mathcad file directly. That means that something on the user side could be the cause for the upload failing (it should not and the problem has to be fixed by Lithium or PTC) and I am curious as to what it could be.
I downloaded gthe files of the people who were successful and trie to upload the very same files - no succes. So its nothing special with the files.
I usually work with Firefox and so I gave it a try with Chrome and with Internet explorer. But with none of them I was succesful, all would refuse the upload.
At the time I am limited to a machine with good old  Win XP.
Could the OS be the difference, or the installed Java version, or ....??
Could you please try yourself to upload a Mathcad file directly and report here about fail or success!?
Maybe your responses can help Toby to find a solution.
If you need dummy files you can find thme in the attached archive.
Jul 11, 2017 2:18 PM UTC
Hi Werner,
Now I tried to attach your files, but it gives me some errors. They must be stored in a compressed folder. My O. S. is w10, Java 7 version 9
23-Emerald I
Jul 11, 2017 2:24 PM UTC
I must zip version 15 and Prime 3.0 files to upload them.
Windows 7 Pro
IE 7.0
Jul 11, 2017 2:45 PM UTC
Hallo Werner,
Trying to upload each of your files directly leads to this message:
 I'm working with OS Win10 and MP4+MC15 and I'm using firefox as well.
In the thread:
https://community.ptc.com/t5/PTC-Mathcad-Questions/Export-to-pdf-xps-changes-plot-axis/m-p/476637#M172254
a user could upload the file Propped steel beam.mcdx directly.
I couldn't upload his file directly, getting the same error message like above.
To upload directly pdf-files, it's no problem.
Werner_E25-Diamond IAuthor
Jul 11, 2017 3:28 PM UTC
Thanks for all the replies so far.
I already suspected to get a better reaction here than in "Community Help" 😉
So far nobody was successful in uploading a Mathcad file directly without zipping it first.
The good part ist that I see that I am not alone and its not just me 😉
On the other hand It is becoming increasingly mysterious as to how those two useres succeeded here. One of them was referenced by Volker in his reply above,  the other is anthonyQuinn here https://community.ptc.com/t5/PTC-Mathcad-Questions/MathCad-11-how-to-make-the-result-shown-in-line-with-the/m-p/476124#M172199
Third post in the thread (unfortunately we can't link to individual posts in a thread any more).
So other users are welcome to chime in here. Whats your experience when you try to attach a Mathcad file directly?
Jul 11, 2017 4:59 PM UTC
Maybe Adam could tell us something about his OS and settings.
We should ask him for information about like that.
Jul 11, 2017 7:41 PM UTC
OK, lets invite @am-a to this dicussion, but I fear that his explanation will be similar to Anthony's in the other thread. Anthony wrote "About .mcd attachment, I did nothing in particular. I just browsed with the link that there is here under the edit window  on the left  and selected the file (I am working - if that matters - still with WinXP)."
In other words it simply worked for him as it should.
Jul 11, 2017 6:15 PM UTC
No luck.
Win 10, Firefox.
Jul 11, 2017 7:48 PM UTC
OK, thanks!
So far including myself six users reported here and all six were unable to attach Mathcad files directly.
Keep your reports coming ....
Jul 11, 2017 7:53 PM UTC
I was NOT able to attach the following filetypes:
MC 11 (saved from MC15)
MC 15
MCP 3.1
I got the "...does not match its file extension and has been removed" error for each.
I'm running Win 10 Pro x64 and using Chrome 59.0.3071.115
23-Emerald V
Jul 13, 2017 9:55 PM UTC
Attaching a mathcad 11 file
OS=Win10/32bit, Browser is Firefox.
Edit: OK, let's add a couple of Prime files.
Ah That failed with the message:
23-Emerald V
Jul 13, 2017 9:56 PM UTC
So maybe (considering that Anthony Queen used Win XP, most probably 32-bits)
the magic is in the bitness of the OS...?
Jul 13, 2017 10:14 PM UTC
No, its not the bitness. At the time I am on WinXP 32 bit and am also using FF and no luck re-uploading your file here 😞Pic1.png
It may have to do with the registry settings which control the assignments extension to content-type as shown above but I have no idea what and how.
As I understand it now its our local system which tells Lithium that the attachment is of content-type "application/x-mathcad-mcd" (the first registry entry I showed above) and Lithum then decides (why????) that the extension .mcd is not a valid extension for that content-type. At least that's what I understood from reading the thread in the NI forum I linked to above.
Maybe your system is configured differently and reports a different content-type of the file to Lithium? Can you check?
Have you tried to upload files from the zip file in my initial post (MC15, Prime format)? Guess you would be able to do so, too.
23-Emerald V
Jul 14, 2017 7:28 AM UTC
Upload test:
Only the .mcd file loads up. The remainder:
23-Emerald V
Jul 14, 2017 8:00 AM UTC
Note that my registry shows:
[HKEY_CLASSES_ROOT\MIME\Database\Content Type\application/x-mathcad]
"Extension"=".mcd"
[HKEY_CLASSES_ROOT\MIME\Database\Content Type\Application/x-mathcad-mcd]
"Extension"=".mcd"
[HKEY_CLASSES_ROOT\MIME\Database\Content Type\application/x-mathcad-mcdx]
"Extension"=".mcdx"
So to state that:
"The attachment's UploadTest.mcdx content type (application/x-mathcad-mcdx) does not match its file extension"
is a lie, and to my opinion exposes a severe BUG in the Lithium software.
Oct 19, 2017 1:00 PM UTC
Any news?
Jul 14, 2017 3:53 PM UTC
So, I tested the files with extensions ".mcd", ".xmcd", ".xmcdz", ".mcdx" and all without success. I used the following web browsers with Windows 7 32-bit and always received the same error:
  • Internet Explorer 11.0.9600.18738
  • Google Chrome 59.0.3071.115
  • Firefox 54.0.1
  • Opera 46.0.2597.46
  • Tor 7.0.2
Jul 14, 2017 4:47 PM UTC
Guess we won't solve that puzzle here and have to wait for lithium to reply to Toby. Hopefully wih a fix and not with "its a security feature and working to specification.".
Jul 14, 2017 7:45 PM UTC
In any case this is strange Smiley Frustrated.
