Interpolation between points in Mathcad Prime 3.0
- 19 replies
- 14085 views
- Translate All
Hello all,
I have datapoints, expressed in a x-vector and a y-vector.
Just by plotting x and y the points are already pretty smooth. The gradient between the first x-points is very big, so I would like to smooth the curve even more. How do I do it the best way? Interpolation between points is the answer, but how to I do it in mathcad?
I attached a mathcad prime 3.0 sheet where I try to do some tests, but without success so far.
The graph in the screenshot is already pretty accurate, but thats because I have enough datapoints.
In a worst case, where I cannot obtain enough datapoints, I would need some kind of interpolation...
The optimum would be even to reconstruct a function out datapoints. Is this possible?
I could do further analysis by having a function f(x)
The datapoints were obtained from this graph for thermal resistance over a copper area:
Best regards!
