Multiple-Variable Functions and Plotting - New Critical Limitation?
I'm trying to switch to Prime. Here is a show-stopper that will have me trying Maple for the first time if I can't get it resolved:
I frequently need to create functions with many input variables (sometimes over 10) and plot the results many ways. To work in a 2-D plot, I used to just set some of the variables to constants in the function name in the plot itslef. This no longer seems to work.
I tried an alternate path of using matrix subscripts, but appear to have hit the same limitation.
Show.Stopper.
Am I missing that this very critical past feature is now entirely gone?
Thanks.
My god, why?? Switching means you are using Mathcad 14 or 15 now, right? So why would you voluntarily switch to an inferior version?
2D-plots in Prime have many flaws but what you tried should work, as I understand it. Are you trying to plot a family of curves? Then you should explicitely chose waterfall plot in Prime. This was not necessary in Mathcad and as I had read will not be necessary anymore in Prime 3.
Think it would be a good idea to attach a worksheet (upper right - advanced editor) so we can see what you are trying to do.
Think my remark about the waterfall plot was not appropriate - it refers to plotting matrices.
What I understood from your writing was that you are trying to so something like the attached. It works, but sometimes you have to change the labels of the variables (from variable to none or vice versa) - this is a very annyoing thing in Prime!
One other way:
Possible variant of plotting multiple functions (worksheets for MC14/15 and Prime 3 in attachment):
