how do I get set up for LMS eLearning?
  • March 6, 2021
  • 2508 views
I just purchased a subscription to Creo Parametric.
How do I use the LMS eLearning that comes with it?
Thanks.
Best answer by BettinaGiemsa
You (or someone in your org) should have received an email about this.
Maybe this document will help clarify. https://www.ptc.com/-/media/Files/PDFs/Services/J13654_Renewals-Toolkit_eLearning_EN.pdf
@JeffFilo Can you help?
Bettina
Bettina
I did get eLearning figured out. The best help came from Hedy. Thank you and KUDO's. I am now learning Creo Parametric 7.0.2.0.
