2-Explorer
Jan 11, 2019 9:32 PM UTC
Make Surface Copy Independent - Creo 2.0
See attachment. I have some surface copies that I need to be able to make independent to break the dependencies so that I can check the files into windchill.
I don't care if the surfaces get frozen and aren't linked to anything anymore.
JM_LPEAnswer
2-Explorer
Jan 22, 2019 4:45 PM UTC
So I found that if you make an independent geometry feature, then collapse the surface copy to the independent geometry feature, it gets rid of the dependency.
Quite a few more steps than opening the reference viewer and and RMB->Break Dependency, but it gets the job done.
6-Contributor
Jan 14, 2019 11:32 AM UTC
In Reference viewer switch to show Dependencies instead of References and now you should can do Break Dependency with right click on dependencies arrows.
JM_LPE2-ExplorerAuthor
2-Explorer
Jan 14, 2019 3:57 PM UTC
See attached. I don't see a Break Dependency option. Why would this not show up?
2-Explorer
Jan 14, 2019 6:15 PM UTC
What I ended up doing, because this problem has plagued me for months now, is if for some reason I cant break the dependency in the reference viewer I use the Auto Resolve Incomplete Objects, Update with Object on Server, else ignore option in Windchill. It got the file into Windchill without adding ghost objects or giving me a failed upload error in creo.
In my almost decade of using Inventor and Solidworks, I never was not able to break a dependency/external references, the only consequence was that the geometry was then frozen and became a static feature. It worked exactly like how PTC sometimes does when the Break Dependency option is available.
Seems to me that PTC needs to make it so that RMB menu always has the Break Dependency option in the reference view like the similar functionality of their competitors. That would make life incredibly more easy.
2-Explorer
Nov 11, 2019 2:16 PM UTC
You can copy features from the Assembly window into another part within the assembly window, this will kill the dependency. or copy and save into a stp or iges...
It is not so convenient as the options available on creo 4.0 and upwards.
