Feb 15, 2024 5:20 AM UTC
Design rule check
Software: Creo Parametric 7.0.10.0
I want to assign some sheet metal design rules and have created one. Can we verify those rules in the model. I tried using "MODEL CHECK Rule Check". But I'm getting this error "Cannot read rules from file". I have saved the rules in this filename "design_rule_test.rul" (as saved from Model properties). But in creo documentation, it is mentioned that the file should have ".rule" extension. I have also created "RC_MODEL_TYPE" parameter. How to do this correctly. Am I doing something wrong?
Emeritus
Feb 23, 2024 12:48 PM UTC
Hi Jnithini
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team.
