GPU RENDERING ISSUE
  • October 28, 2022
  • 3 replies
  • 1733 views
I am using Creo Parametric Release 4.0 and DatecodeM150
GPU RENDERING DOSENT SUPPORT PROPERLY WHILE RENDERING. WHILE RENDERING, UTILIZATION OF GPU IS @ 0% ONLY.
KenFarley
A quick search using the search tool at the top of this window leads to the following identical complaint, with an answer that is not what you want to hear.
Previous complaint about GPU inactivity while rendering
I am not sure about creo 4. At some release, PTC started more effectively utilizing the GPU.
What graphics card are you using?
Make sure you don't have any options in your config.pro that is disabling the use of your graphics card.
NVIDIA Quadro T400
Community Manager
November 5, 2022
I am checking in to see if any of the responses was a solution for your issue.    If not, can you reply back on the public thread so more community members can continue to help you?
Post URL: GPU RENDERING ISSUE - PTC Community
Marking Accepted Solutions helps other community members that are having similar issues find solutions. Marked Solutions have the visual indicators on the posts to draw attention to them.
All you have to do is click "Accept as Solution" on the post you feel helped you solve your issue.
 Thank you!
tbraxton
Have you set config options to use the GPU?
https://support.ptc.com/help/creo/creo_pma/r8.0/usascii/index.html#page/rendering/rendering_configuration_options.html
advanced_rendering_mode
auto*, gpu, cpu
Specifies the mode for real-time rendering. Selection of any option takes effect in the next session.
auto—Runs Render Studio in GPU mode if the system hardware supports it, otherwise runs the application in CPU mode.
gpu—Runs Render Studio in GPU mode and allows denoising in real-time rendering.
cpu—Runs Render Studio in CPU mode even if the hardware can run the application in GPU mode.
