Feb 18, 2026 8:33 AM UTC
Please provide clarifications about the error code MKS6188819
What exactly command line option should I use ? Please help. Thank you very much.
The operation could not complete because the working file size exceeds the Server working file size governor.
Use the Add Member From Archive command to re-add the archive, followed by the Check In command with the
Convert Archive to Reference  on Governor option set to check in the working file
We are using Windchill RV&S 13.2.0.3
Pleas see the attached image
Emeritus
Feb 23, 2026 10:06 AM UTC
Hi @AM_7069165,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Best Regards,
Vivek N
Community Moderation Team
