Aug 11, 2025 9:15 AM UTC
Windchill RV&S : Command line window pop-up while adding members in Windchill RV&S version 13.1.0.1
Does anyone know the reason behind this issue? I am getting a command line window pop while trying to add members in configuration management side of Windchill RV&S.
After looking through the client logs. I found out that this :
Running trigger from preference si.AddMembers.post named AMpost command: cmd /k "edit %MKSSI_WORKINGFILE%"
but I didn't found any relevant trigger in either of client or server side of the Windchill RV&S.
Emeritus
Aug 18, 2025 11:51 AM UTC
Hi @HR_11916392,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best Regards,
Vivek N
Community Moderation Team
Aug 19, 2025 12:12 PM UTC
Hi Vivek,
Thanks for the response!
I have already attached the screenshot for reference.
Harsh
