delete traceability links
i would like to know is there other methods to delete traceability links for reference(upstream,downstream) and for association please
Emeritus
Hello @ヒエ_13671392,
Thank you for using PTC Community.
In order to receive meaningful responses from other community members, could you please provide more details and context regarding your inquiry? Specifically:
  1. Could you share which tool or platform you're using?
  2. Are you looking to delete these links manually or automate the process?
  3. Are you facing any errors or limitations when trying to delete the links currently?
  4. Is there a particular reason you're removing these links—like cleanup, migration, or restructuring?
You might also find it useful to refer to the guide on how to ask a good question. This will enhance the likelihood of receiving valuable assistance from other Community members.
I hope this information is helpful.
Best Regards,
Vivek N
Community Moderation Team.
I’ve figured out how to manually delete reference links and association links using the field method and the delete function in the association tab.
I’m wondering if there are alternative methods to perform this cleanup?such as using MS Project import/export or other tools or techniques.
That’s all I’ve discovered so far, but I’m very curious about the cleanup, migration, and restructuring processes you mentioned. If you have an article or documentation explaining these topics, I’d be very grateful to receive it.
Thank you!
