Ability to Search the Services of a Database Thing for a specific string value
We are using ThingWorx Platform 9.6.  Is there a way to search the services attached to a database thing?  For example, I want to know each service that contains a SQL Server Table named Customers?  Is there a way to search the SQL queries within each service and return a list of all services that contain this table?
Rocko
RockoAnswer
You can run Resources["EntityServices"].ReadEntityAsJSON() and then browse the result, it's probably somewhere under effectiveShape.serviceImplementations.<SERVICENAME>.configurationTables.Query.rows[0],sql
You will have to iterate over all services and filter for the ones with handlerName="SQLQuery".
Rocko
Rocko19-TanzaniteAnswer
Support
July 15, 2025
Hi @SB_12787070,
It appears that this post may answers your question.  For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Abhi
