After Server rehosting, I am getting errors while connecting Navigate to odata connector
  • August 12, 2024
  • 2 replies
  • 937 views
After Server Rehosting, Iam getting this errosrs while connecting navigate to odata connector. How to fix this.
Errors are:
Your route exchange has failed. Resource Error [Connection reset by peer: socket write error]
Could not dispatch async service request [NotifyPropertyUpdate] : Error: No service named NotifyPropertyUpdate is available.
Your route exchange has failed. Resource Error [Received fatal alert: unknown_ca]
Transaction has been marked as a failure for request /Thingworx/Things/PartStructureAccessAppThing/Services/GetRepresentableInfoForUniqueResource
Exception executing service, GetRepresentableInfo, on resource provider: WindchillDemoPartResourceProvider
Unable to Invoke Service GetEndpointDefinition on Windchill-Odata-Connector : Your route exchange has failed. Resource Error [Failed to aggregate all metadatas, 10 were expected, but only 0 received]
IntegrationSubsystem: numberOfConnectors= 10, requestCount= 9
Hi @AP_10744603  Can you take a look at the below article and let us know your feedback?
https://www.ptc.com/en/support/article/CS343365
Hi @AP_10744603 ,
It appears that this there is an answer to your question.  For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Pehowe
