May 20, 2024 11:23 AM UTC
CWC- WorkOrderUtilities
After installing CWC 9.5.0 Work Order Utilities cannot seen in configuration. Kindly check attached image
SebBAnswer
May 28, 2024 1:04 PM UTC
@KG_96  I just checked the code, and it looks like the extension does not have any specific dependencies on 9.5.1. You can try importing it to 9.5.0, i just did not test it on that version.
May 21, 2024 8:27 AM UTC
Quote: "After importing and deploying the PTCSE.WorkOrderUtilities Building Block, users with the right permissions (see Access Control page) can access the user interface through the Configuration menu context in the ThingWorx Applications".
KG_9610-MarbleAuthor
May 21, 2024 10:17 AM UTC
where I get PTCSE.WorkOrderUtilities Building Block
May 21, 2024 6:40 PM UTC
You can find "ThingWorx Applications Work Order Utilities Installation Guide" in attachment.
Emeritus
May 27, 2024 2:33 PM UTC
Hello @KG_96
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.  Or if you found a solution on your own, please document it in your topic and mark it as accepted solution. This will surely help other users who may have a similar question.
Community Moderation Team.
May 28, 2024 5:27 AM UTC
Can you send files which support to V 9.5.0.Because we have just now upgraded from 9.3 to 9.5. It's difficult to further upgradation.
SebB13-AquamarineAnswer
