PEHOWEAnswer
May 22, 2025 6:47 PM UTC
Hello @AP_10343008 ,
Did you get what you need?
For a post operation in POSTMAN, the URL looks like:
<protocol>://<ServerName/IP Address>:<portNumber>/Thingworx/Things/<thingName>/Services/<serviceName>
Then in the header I passed an appKey. accept, content-type,
The Body has a JSON object with the parameter and value.
Hope this helps.
Pehowe
Apr 28, 2025 8:20 AM UTC
Are you invoking that endpoint using a POST or GET method?
A service must be invoked using POST? (It is possible to override that behavior using the "Allow Request Method Switch" option)
Emeritus
May 2, 2025 9:48 AM UTC
Hello @AP_10343008,
It looks like you have a response from a PTC Support engineer. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
May 8, 2025 12:35 PM UTC
Have you used POSTMAN tool to test your URL? The tool provides great feedback and error reporting.
REgards,
pehowe
PEHOWE17-PeridotAnswer
Hope this helps.
Pehowe
