11-Garnet
October 1, 2025
File upload to azure blob storage
  • October 1, 2025
  • 2 replies
  • 501 views
Hello guys,
we only have service principal authentication method, Azure IOT Hub is not supporting this authentication.
am looking for an option to upload file to azure blob storage from thingworx by any extension.
please suggest a way.
thanks
Hi @Janaki.Raman
Try to use Azure blob storage rest API access – go though and integrate the following article steps,
https://www.ptc.com/en/support/article/CS392915?source=search
Support
October 22, 2025
Hi @Janaki.Raman
It appears that this post answers your question.  For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Charles
