How to create style definition through services in thingworx ?
  • July 3, 2018
  • 4 replies
  • 2609 views
I need to get the input from the front end mashup then i like to create the style definition based on the input using services, further i like to update the particular widgets style definition with that newly created style.
thanks in advance...
Best answer by CarlesColl
Combining both and after some tests, this is the correct format :
var name = "NewTestStyle3";
try{
 Resources["EntityServices"].CreateStyleDefinition({
 description: undefined ,
 content: { "content" :
 { "params": "",
 "image":"",
 "backgroundColor":"#d49d13",
 "textSize":"normal",
 "lineStyle":"dotted",
 "displayString":"Series 15",
 "fontEmphasisUnderline":false,
 "fontEmphasisItalic":false,
 "lineThickness":1,
 "lineColor":"#ffac20",
 "foregroundColor":"#ffdc84",
 "fontEmphasisBold":false,
 "secondaryBackgroundColor":"#ffb22f"
 tags: undefined
}catch(err) {
 logger.error("EERROR STYLE CREATION "+err);
 Resources["EntityServices"].DeleteStyleDefinition({
There is a snippet:
var params = {
	name: undefined /* STRING */,
	description: undefined /* STRING */,
	content: undefined /* JSON */,
	tags: undefined /* TAGS */
// no return
Resources["EntityServices"].CreateStyleDefinition(params);
But I don't know how to use it properly.  I am curious about how to do this too.
thank you for your reply xavior,
i know there is a separate snippet available in the service part. but i also dont know how to use that one.
In that snippet where do we need to give input for color code and text format?
If you look at my answer on how to get Style Information: https://community.ptc.com/t5/ThingWorx-Developers/Get-style-information-of-style-definition/m-p/548275
you can see that the context format for style may look something like:
 "image":"",
 "lineThickness":1,
