6-Contributor
Feb 10, 2025 7:25 AM UTC
I need CWC extended extension for QA report & File attachment option in execution verification step
I need thingworx cwc extended extensions for features like QA report, Audit Report, Attachements/ logsheet upload in work instruction verification step.
Rocko
Feb 10, 2025 7:49 AM UTC
And what is the question you have?
https://github.com/PTCInc/solution-cwc-extended
6-Contributor
Feb 10, 2025 9:07 AM UTC
Hi, Thank you for the link.
I have imported extension successfully, but how I can set Thing:PTC.FSU.CWC.EXT.Installer.AutomatedInstallHelper_TG
this thing in order to proceed further. If you have any documents on it's configuration steps then would be helpful. Thanks
Feb 13, 2025 2:18 PM UTC
Hello - it appears that maybe your database connection is not configured correctly?  Please open your PTC.FSU.CWC.EXT.MSSQL_TG thing and go to the Configuration section.  Validate that your database is configured correctly.  If your standard CWC is connected and working correctly, it is likely the same configuration that is in the PTCFSU.CoreSQLThing thing.
If your database is connected, the isConnected property should be true (checkbox is checked).  After making configuration changes, save the thing and then run the RestartThing service and check the isConnected property.
Once your database is properly connected, you should be able to manually uninstall / reinstall features as needed.
Emeritus
Feb 17, 2025 8:02 AM UTC
Hello @CV0893,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
