Pie Chart to Donut Chart and add boundary to the bar chart
Can this pie chart be possibly changed to a kind of donut chart, by Thingworx composer?
I also want to draw a upper boundary in this bar chart, how? Like draw a line in 30000.0.
jamesm1Answer
Here is a D3 Pie Chart Widget that has a donut feature via setting the inner radius. Note that this widget is provided as an example and is not officially supported; it also may conflict with other widget extensions that use the D3 library.
Tiantian Guo​,
Per my understanding Donut like Pie chart is not available out of the box.
You will have to create your own custom extension for this feature.
tguo1-VisitorAuthor
Ok. Understand it is needed a plug-in to change pie chart to donut chart.
And for the bar chart? Is it possible to draw some threshold line in bar chart?
Ankit Gupta​
Tiantian Guo​,
There is no out of the box option to set the Threshold in the bar chart. You will have to customize the extension to add this feature.
yea it can be achieved through customisation of these widgets and i have done this.
