Problems to run EMS on Raspberriy Pi 5
  • March 8, 2025
  • 2 replies
  • 744 views
Hi, I downloaded the file "MED-61060-CD-054_SP10_Microserver-Linux-arm-hwfpu-openssl-5-4-10-1509.zip" on my raspberry pi 5, I unzip it and I followed all the instruction from this article: "https://community.ptc.com/t5/IoT-Tips/Connect-Raspberry-Pi-to-ThingWorx-Part-1/ta-p/825298#toc-hld-1818354262".
unfortunately, when I tried to run the wsems, I am having the error in the console window :sudo: unable to execute ./wsems: No such file or directory
I checked the permission and the OS architecture and is ok:
-rwxrwxr-x 1 PI PI 963832 Apr 29 2021 wsems
aarch64
but I am not able to run the wsems, could you please advice me how to correct this?
Thank you.
Best answer by VladimirN
Take a look:
VladimirN24-Ruby IVAnswer
Take a look:
Community Moderator
March 14, 2025
Hello @FT_11364686
You have a response from a community champion. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
