Mar 27, 2024 5:05 AM UTC
Property values are repeating while using QueryPropertyHistory Service in ThingWorx
Hello Everyone
Good Evening,
I am facing problem in logging properties there are some values which are repeating after I carry out the experience multiple times.
PFA attached image in which arrows are shown on the readings which are repeating when I consume the AR experience on my Ipad on view app for multiple times.
I just want to log the properties which are entered by the user on vuforia view app.
Below is the code I am using to write properties from Vuforia Studio to Thingworx:
I have written 2 services for pass & fail
Vuforia Studio JS Code:
$scope.SetStartStagePass = function (width) {
var TWXmodelID = 'Camera_UserStats_DT';
    var serviceName = 'GetSummary';
    var d = new Date();
    var parameters = { 'Emp' : $scope.app.params.empID, 'PartNumberInput' : $scope.app.params.partNo, 'Stage' : 'Step-' + j, 'StepValue' : 'Pass', 'DefectInput' : 'NA',
                      'StepImageInput' :  $scope.view.wdg['camera'].image};
    //console.log("Starting UPLOAD using image size " + width);
    twx.app.fn.triggerDataService('Camera_UserStats_DT', serviceName, parameters);
$scope.SetStartStageFail = function (width) {
    var d = new Date();
    var parameters = { 'Emp' : $scope.app.params.empID, 'PartNumberInput' : $scope.app.params.partNo, 'Stage' : 'Step-' + j, 'StepValue' : 'Fail', 'DefectInput' : $scope.app.params.defect,
Thanks in Advance.
VelkumarAnswer
Mar 28, 2024 7:57 AM UTC
Hi @Aditya1702
Instead of logging data into the ValueStream. You can use Stream or DataTable (if it is low-frequency data) to store data in Thingworx which will avoid multiple entries.
Please refer here for DataTable services -Data Table Services (ptc.com)
About stream -Streams (ptc.com)
/VR
Rocko
Mar 27, 2024 12:57 PM UTC
Did you forget an attachment?
Mar 27, 2024 1:04 PM UTC
Yes I forgot, I am attaching it now.
My purpose is I want to enter records row by row into an infotable.
eg, I have these field definitions in datashape: ID, Name, Status, TimeStamp - I want to enter records for these columns,
Record1: 1, Name1, Pass, 27/03/2024
Record2: 2, Name2, Fail, 27/03/2024
Record3: 3, Name3, Pass, 27/03/2024
Thanks in Advance.
Velkumar19-TanzaniteAnswer
Hi @Aditya1702
/VR
Apr 2, 2024 12:26 PM UTC
thanks for sharing
Emeritus
Apr 4, 2024 5:08 AM UTC
Hello @Aditya1702,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
Apr 4, 2024 5:42 AM UTC
Hello Everyone,
@H_1234 , @Velkumar , @Rocko , @
Thank you for your support. I am using Datatable instead of Streams to store records into ThingWorx. Its working properly at present.
Best Regards,
Aditya Gupta..
