Oct 7, 2020 7:27 AM UTC
ThingWorx CI/CD
I would like to ask about the best approach for CI/CD. Right now we are facing issues, when multiple developers are working simultaneously and they are influencing each other. What is the best approach to mitigate this?
I found this article https://community.ptc.com/t5/ThingWorx-Developers/Thingworx-and-Visual-Studio-Code-with-any-Source-Control-CI-CD/m-p/598767
Unfortunately I am unable to make it work. Thank you
Oct 7, 2020 11:56 AM UTC
While I can't give you a perfect recipe for this, I can point you in the direction of a very nice article wrote by my colleagues from the Enterprise Deployment Center. The article is available here: https://community.ptc.com/t5/IoT-Tech-Tips/ThingWorx-DevOps-with-Jenkins/m-p/684393#M1683
The TLDR version is the following:
-you need a devops engineer
-within PTC we have built as an example, a Jenkins-based CI/CD Chain (also includes a testing framework). Kudos to Costin Badici for his initiative around this.
-the devops engineer can look at this example and design, based on it, your own CI/CD chain in any other tool you use internally
If you want, we also have the capability to help you design such a chain, please contact your Customer Success Manager and ask for this kind of support. Note that without devops skills that handle all the microissues related to such a chain, it is usually hard to maintain it correctly, as it always evolves in some direction or another.
Support
Oct 16, 2020 1:01 PM UTC
Hi @czjakubo.
If you are satisfied with the response provided by @VladimirRosu_116627, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
