Dec 10, 2024 11:20 AM UTC
Writing Custom Thingworx Service 400 - 500 Level Error Return Code
I want to do something like this -
try{
if(someError)
   throw someErrorException()
}catch someErrorException{
result.message  = "someError happened"
Expected output in postman if the someError condition is true -
Status Code = 500 & response message = someError happened"
Instead of this, I am able to get it into status code 500 by forcefully writing erroneous code within the if statement but I am not able to set the error message. Its the standard error message which comes - "XYZ check scriptLog"
18-Opal
Dec 10, 2024 1:40 PM UTC
Don't catch your exception. Instead of that simply try:
throw "Some error happened";
 / Constantine
Mar 20, 2025 1:37 AM UTC
Hi @AD_10324110
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution for the benefit of other members who may have the same question.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to support.
Wenjing
