6-Contributor
February 19, 2024
add a subscription to thing via rest api
  • February 19, 2024
  • 2628 views
I need to add a subscription to batch things,how to add subscription to thing via rest api?
Best answer by Velkumar
Hi @YC_10946483
If you are asking about Dynamic Subscription
You can use the below endpoint
https://<<HOSTNAME>>/Thingworx/Things/<<THINGNAME>>/Services/AddDynamicSubcription
Method : POST
Content-Type : application/json
Body :
 propertyName: logicProp,
 eventName: "Alert",
 thingName: undefined,
 serviceName: "SubscriptionActionService"
Please refer this article for different input parameters - Article - CS388158 - Working with Dynamic Subscriptions in ThingWorx Platform (ptc.com)
/VR
Hi @YC_10946483
You can add Dynamic Subscription in RunTime or via API
Please refer to this article : Article - CS388158 - Working with Dynamic Subscriptions in ThingWorx Platform (ptc.com)
/VR
6-Contributor
February 19, 2024
This method must  create service before execute AddDynamicSubscription, i need  add a subscription with my javaScript code and deal with some logic,is there any  other method can resolve  this?
Rocko
You could add the service via API before and reference that in AddDynamicSubscription. https://community.ptc.com/t5/IoT-Tips/Create-a-service-dynamically/ta-p/820425
Or you can import a new Thing from XML and you generate the XML to have the code you want.
In any way, when you have code, you will change the Thing Model. Dynamic Subscriptions alone don't change the Thing Model.
