Jamal Ashraf
Jul 16, 2024 7:25 AM UTC
Integration Windchill and Vuforia Studio
Hey Community,
Is there any possible way to integrate Windchill and Vuforia studio. My use case here is, I need to list out all the available 3D model available in Windchill into Vuforia Studio screen, based on user selection I need to show 3D model in 3D Model widget. This question has already been asked in forum but i still could not find a right answer and definetly need more insights into this topic. Please give your valuable feedback.
JA
Jul 16, 2024 7:51 AM UTC
Hi @MA8731174 ,
you can download data possibly directly from windchill or other server but that will not work because of CORS. So means that Vuforia View will not allow a call via different domains. so therefore the supported way is to use Windchill data --> to Thingworx repository --> Vuforia Studio
Here I want to refer to point 1.) of that post : https://community.ptc.com/t5/Vuforia-Studio/Is-there-a-way-to-load-3D-model-from-Thingworx-repository-to/td-p/961474
Jul 16, 2024 1:39 PM UTC
for the Integration  from  windchill to TWX - so the step is to export first from Windchill the  pvz files as export to folder  - as the part what is visualization /Windchill adapter could be seen in the article   https://www.ptc.com/en/support/article/CS112832
  1. In Windchill, if GDD is enabled, export pvz file generated by Creo View Adapters.
  • How to create a Graphics Dynamic Document (GDD) that can be opened in IsoDraw or in Creo Illustrate from Windchill ?
  • Can Creo Illustrate be integrated with Windchill PDMLink to load published CAD representations?
  • How to create a PVZ automatically after publishing a CAD Document, that can be imported into Creo Illustrate?
  • How to generate a Publication Graphic or Dynamic Document published automatically for use in Creo Illustrate?
  • How to publish representation to pvz format
  • A workflow from initiation to completion
    Res:
Emeritus
Jul 19, 2024 11:47 AM UTC
Hello @MA8731174,
It looks like you have some responses on your topic. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
