Hi @DenGrz ,
today I tested the issue further with a pipe in z-direction and see there - then the " shader did not work. And this seems to be a problem of the shader implementation it self. Because when I rotate the pipe in the Y direction then was working fine. It works only flat in the x,y plane. So , this required to check the shader implementation more detailed. The solution is some kind of rotation of the shader along the Y -axis:
So changed the shader defintion (for the red pipes) to this - added addtional argument for Z-roation:
<script name="texture_test1" type="x-shader/x-fragment">
precision mediump float;
uniform sampler2D Texture0;
uniform float lightscale;// light intensity
uniform float scale;
uniform float moveX;
uniform float moveY;
uniform float rotZ; //
#define PI 3.14159265359
// determine varying parameters
varying vec3 N;
varying vec4 vertexCoord;
// determine shader input parameters
uniform vec4 surfaceColor;
//light positions from pont to zerro
const vec3 lightPos = vec3(3.0, 3.0,1.0);//light postion see the pulb in model
const vec4 ambientColor = vec4(0.5, 0.5, 0.5, 1.0);
void main() {
// calc the dot product and clamp based on light position
// 0 -> 1 rather than -1 -> 1
// ensure everything is normalized
vec3 lightDir = -(normalize(lightPos));
vec3 NN = normalize(N);
// calculate the dot product of the light to the vertex normal
float dProd = max(0.0, dot(NN, -lightDir));
// calculate the color based on light-source and shadows on model
vec2 TexCoord = vec2( 0.0,0.0);
// here the rotation along the Y -axis
// affects only the X axis
float ang= rotZ*PI/180.0;
TexCoord.x= scale*( cos(ang)*vertexCoord.x + sin(ang)*vertexCoord.z);
TexCoord.y = scale*vertexCoord.y;
TexCoord.x=TexCoord.x+moveX;
TexCoord.y=TexCoord.y+moveY;
vec4 color = texture2D(Texture0, TexCoord) ;
gl_FragColor = (ambientColor*lightscale + vec4(dProd)) *color ;// surfaceColor;
</script>
<script name="texture_test1" type="x-shader/x-vertex">
attribute vec3 vertexPosition;
attribute vec3 vertexNormal;
varying vec3 N;
uniform mat4 modelMatrix;
uniform mat4 modelViewProjectionMatrix;
void main() {
vec4 vp = vec4(vertexPosition, 1.0);
gl_Position = modelViewProjectionMatrix * vp;
vertexCoord = modelMatrix*vp;
// the surface normal vector
N = vec3(normalize(modelMatrix* vec4(vertexNormal,0.0)));
</script>
And here the usage in the code:
$scope.app.shaderString1="texture_test1;scale f .5;moveX f 0;moveY f 0;rotZ f 90.0;lightscale f 1.0";
//in init function
for(var j=6;j<8;j++){
$scope.view.wdg['modelItem-'+j]['texture'] = "app/resources/Uploaded/waterred.jpg?name=Texture0&edge=repeat";
$scope.setWidgetProp('modelItem-'+j, 'shader', $scope.app.shaderString1);}
$scope.$applyAsync()
$scope.app.setShaderNew1= function(widgetName,scalepar,xDir,yDir,zRot,delay,duration)
var calldelay =3000; //3 seconds
var callduration=10000;//10secs
var jumpInterval=5;
if(delay !=undefined) calldelay = delay;
if(duration !=undefined) callduration = duration;
$timeout( () => {
$interval(function() {
if($scope.val >500) $scope.val =0
else $scope.val +=1
var scale= parseFloat(scalepar);
var moveX= $scope.val/500*xDir;
var moveY= $scope.val/500*yDir;
var rotZ= zRot;
var transp= 0.75+0.25*(Math.sin(12.0*Math.PI*$scope.val/500));//6 waves
$scope.app.shaderString = "texture_test1;scale f "+scale+";moveX f "+moveX+";moveY f "+moveY+ ";rotZ f "+rotZ+ ";lightscale f "+transp;
$scope.setWidgetProp(widgetName, 'shader', $scope.app.shaderString);
$scope.view.wdg[widgetName]['opacity'] =transp;
if(debug) console.info( $scope.app.shaderString)
}, jumpInterval, callduration/jumpInterval)},calldelay);
$timeout( () => {$scope.setWidgetProp(widgetName,'shader',"Default")},calldelay+callduration);
$scope.app.myButtonFunction= function( ){
$scope.app.setShaderNew('modelItem-1', 1.0, 1.0, 0.0,2000,15000)
$scope.app.setShaderNew('modelItem-2', 1.0, 1.0, 0.0,2000,15000)
$scope.app.setShaderNew('modelItem-3', 1.0, 0.0, 1.0,2000,15000)
$scope.app.setShaderNew('modelItem-4', 1.0,-1.0, 0.0,2000,15000)
$scope.app.setShaderNew('modelItem-5', 1.0, 0.0,-1.0,2000,15000)
// here the new call
$scope.app.setShaderNew1('modelItem-6', 1.0, 1.0, 0.3, 90.0,2000,15000)
$scope.app.setShaderNew1('modelItem-7', 1.0, 1.0, 0.3,-90.0,2000,15000)
So now it will works with a fluid flow in all directions:
