problems with Model target
  • March 17, 2025
  • 3 replies
  • 726 views
 I am using the Model Target and I want that when I point to the Model Target I get information about the object but I don't know how to do it.
Does anyone know of a Tutorial or a project that does something similar with documentation?
I am using Unity 2022.3.45f
Hi @CG_13054620 ,
because you mentioned in your question unity version   therefore I think your question is   related   to Vuforia Engine & Unity   and is not directly related to the to the  Vuforia Studio product and Vuforia Studio community  .  Therefore I want to refer to  to the Vuforia Development portal/ support -  https://developer.vuforia.com/support where you could find Information and Tutorial to the  Vuforia Engine /also usage in  unity enviroment /
You have also the option to address your questions and discuss issues with other Vuforia Engine and Unity developers via the official vuforia tag on Stack Overflow  https://stackoverflow.com/questions/tagged/vuforia
So using a modelTarget in Studio there was already a reference provided by @VladimirN  answer
To handling a ModelTarget in unity there is the start reference in the Vuforia developer portal
https://developer.vuforia.com/library/vuforia-engine/images-and-objects/model-targets/model-targets/
and especially for unity usage of ModelTargets:
https://developer.vuforia.com/library/vuforia-engine/images-and-objects/model-targets/unity-guide/introduction-model-targets-unity/
In the Unity asset store you can find  Vuforia Engine samples asset (Vuforia Coree Samples ) which could be downloaded :
https://assetstore.unity.com/packages/templates/packs/vuforia-core-samples-99026
So far I know there is also example for the usage ModelTarget https://youtu.be/nEUatujxE5I
So I hope that information cold help. If not then , please address your question in the overflow Vuforia
Community Moderator
March 24, 2025
Hello @CG_13054620
It looks like you have some responses on your topic. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
