Chris3
Can't up vote (kudos) your own idea anymore?
Looking at past ideas it looks like if you up voted an idea in the old Jive system it carried over but the new Lithium system won't let you give your own idea an up vote? Am I missing something or just don't it wrong?
TomUAnswer
That is correct.  You cannot vote for your own post/idea.  You also can't downvote an idea.  You either upvote (give kudos) or you don't.
TomU23-Emerald IVAnswer
Emeritus
July 10, 2017
I have made the request within Lithium to:
  1. Be able to vote for my own idea
  2. Get an automatic vote for submitting
Toby
How come clicking on Kudos counter makes it go DOWN now ?
StephenW
I noticed that also. I guess that eliminates the "don't forget to vote for you own idea" problem with Jive ideas.
If you do give a kudo and want to remove it, you can do that. With Jive, once you voted, you couldn't remove your vote, you could only make it the opposite vote.
Dale_Rosema
But what if you think it is a bad idea. Now that is just the same as never having seen the post or ambivalence.
Emeritus
July 7, 2017
Hi @Dale_Rosema -
@StephenW is correct:
"If you do give a kudo and want to remove it, you can do that. With Jive, once you voted, you couldn't remove your vote, you could only make it the opposite vote."
The Lithium functionality is similar - if you like an idea, you can vote for it, if your mind changes, you can remove your vote.  If you believe it is a bad idea, please leave a comment with your suggestions.
Best,
Toby
This isn't really solved, because it's still under request.
See @Tmetcalf's post below:
https://community.ptc.com/t5/Welcome-How-To-s/Can-t-up-vote-kudos-your-own-idea-anymore/m-p/476600#M168
StephenW
I would say the original post is solved with respect to the current Lithium functionality. You can not vote on your own idea.
Toby had requested from Lithium that an enhancement (or fix) be made to add the automatic up vote for the original poster and/or to allow the original poster to add an up vote.
Since Toby is no longer with PTC, I don't know if Jaime Lee is pursuing this concept or not.
If you would like to add feedback for Jaime, you can do so at the link below which is the new area for community complaints/ideas/enhancements/fixes, whatever you want to call it.
https://community.ptc.com/t5/Community-Feedback/How-to-Use-This-Community-Feedback-Board/m-p/485356#M1
