8-Gravel
May 6, 2024
Custom attributes Folder via API
  • May 6, 2024
  • 2 replies
  • 2003 views
Version: Windchill 13.0
Use Case: We want to add some custom attributes to folders that we will need to modify during in certain cases.
Description:
Hello everyone,
I wanted to know if there is a way to make it possible to modify custom attributes for folders via API cause I'm having problem with a customization since I'm able to access only to the default "Description" attribute.
Thank you in advance
Best answer by HelesicPetr
Hi @AK_10639313
Additional info.
Sometimes It is very useful to check the JavaDoc documentation to understand what the service can do.
PetrH
HelesicPetr
Hi @AK_10639313
Try the persistable adapter and PersistenceHelper
PersistableAdapter folderObj = new PersistableAdapter(persist, null, null, null);
folderObj.load("IBANAME", "name");
folderObj.set("IBANAME", "my value");
Object obj = folderObj.apply();
PersistenceHelper.manager.store(obj);
example also mentioned in https://www.ptc.com/en/support/article/CS149150?
replaced old api with new one> https://www.ptc.com/en/support/article/CS138252
PetrH
8-Gravel
May 10, 2024
Sorry for the late reply and thank you a lot for sharing a possible solution,
I tried to do as you said but it didn't apply the changes on the attributes of the folder.
HelesicPetr
Hi @AK_10639313
You need to find a reason, why the change has not been stored(saved)
PetrH
Community Moderator
May 10, 2024
Hello @AK_10639313
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Community Moderation Team.
