11-Garnet
Jul 24, 2024 9:30 AM UTC
How to check WTPart if which is don't have parent using Info-engine
Version: Windchill 12.1
Use Case: How to check WTPart if which is don't have parent using Info-engine
Description:
bhushan.dAnswer
Jul 25, 2024 10:14 AM UTC
Hi @ukrishnan-3 ,
You can leverage Query-Links Webject available Out-Of-The-Box.
Example of Query-Links Webject is given in article:
How to implement/use the "Query-Links" webject in Windchill PDMLink
Also, you can refer to Help Center Topic : Query-Links (ptc.com)
Bhushan Dhamdhere
bhushan.d17-PeridotAnswer
Hi @ukrishnan-3 ,
Bhushan Dhamdhere
Emeritus
Jul 31, 2024 12:10 PM UTC
Hello @ukrishnan-3,
It looks like you have a response on your topic. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
