7-Bedrock
Oct 17, 2024 2:07 AM UTC
Multiselect Data utility for multivalued attributes
Version: Windchill 13.0
Use Case: Using the + sign on multi-valued attributes with enumeration or pick list is an awful UX design. Has anyone built a data utility or interface JSP to populate using drop down checklist or a multi-select check list (like the type manager has).
Description:
when selecting multiple values for an attribute, there is a + (plus) sign to add another row to pick more values.   All other interfaces in the world (including type selection in the search ) us pull-down checkboxes, or pick list
has anyone already built the customization to do this that can be easily plugged in.  (Hopefully would be universal to handle any attribute)
Emeritus
Oct 22, 2024 3:29 AM UTC
Hi @DM_01_9885362,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Vivek N
Community Moderation Team.
Nov 28, 2024 5:58 PM UTC
Also looking for this exact thing.
Mar 17, 2026 2:09 PM UTC
Has a solution been found for this yet?
I’m currently facing the same problem.
