May 16, 2024 10:03 AM UTC
can you please explain the detailed steps to registered JSP files for attached document ?
Hello
can you please explain the detailed steps to registered JSP files ?
I registered Datautility, added property file location into  "TgsPropertyHelper". but not getting idea how to register the "createDocumentSetTypeAndAttributesWizStep.jsp" and "loadStateNames.jsp" JSP files ?
please find attached file for reference
HelesicPetr
May 16, 2024 10:31 AM UTC
Hi @WT_010219
Please download a Customization guide and search for custom/wtCustomActions.xml where the actions are defined
https://www.ptc.com/en/support/article/CS60345
page around
1616 Add Custom Commands
or help center
Server Side Customization
PetrH
WT_01021910-MarbleAuthor
May 16, 2024 10:37 AM UTC
Thanks for your reply @HelesicPetr
My question was in reference to below attached file.
HelesicPetr
May 16, 2024 10:53 AM UTC
Hi @WT_010219
You don't need to register jsp pages, Just store them to the codebase/netmarkets folder to respect your package and use them in browser.
In some cases the location is in web-inf folder...
PS> if you share your problem, and describe some more details of your work with errors it could help to understand your issue,
PetrH
Emeritus
May 23, 2024 12:33 PM UTC
Hello @WT_010219,
It looks like you have some responses from a community member. Please reply to the questions from "HelesicPetr".
Or, if any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
