May 6, 2024 10:47 AM UTC
Error in Windchill Modeler, FlexNet Licensing error:-96,7.
I am suddenly facing an issue on running the Windchill Modeler application and facing the FlexNet Licensing error:-96,7. No changes were made to the Host ID or Host name of the server too.
May 6, 2024 10:54 AM UTC
Hello Aarushi,
Please check the installed license file from License Manager and see if the host name and host id is correct. You can also check the Article - CS345349.
Thanks!
Hello Aarushi,
Thanks!
Emeritus
May 10, 2024 6:41 AM UTC
Hello AarushiS,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Community Moderation Team.
