amund
Export History Tab Information
  • April 3, 2024
  • 1978 views
Hi All,
Is there a way to export the history tab information to a searchable file format?
Currently it would be necessary to search the contents of the History tab from project items. One project item contains over 40,000 documents. Scrolling through the entries by hand is simply too time-consuming as, for example, "Documented by" is re-listed every time a new document is created. This entry can therefore be listed several times a day with 40,000 IDs.
Unfortunately, the History tab offers no way of filtering the entries, otherwise you could simply hide them.
Does anyone have an idea or solution?
It is important that it is searchable after export. Preferably in a format such as Excel or similar.
            Please refer to the following two screens, these should help you to pull out the information you need. There is a export of all information  on a page, there is an ability to export a specific timeline and there is a Find on Page to help retrieve information.
amund
amund13-AquamarineAuthor
Thank you very much for your feedback, but we do not use the refreshed web interface as it does not offer any features that we need in our daily work. We use the client or the "old" interface.
Community Moderator
April 10, 2024
Hello @amund
It looks like you have a response to your topic. If it helped you solve your question please mark it as the Accepted Solution.
Community Moderation Team.
